Trang 17 của 36 Đầu tiênĐầu tiên ... 7151617181927 ... CuốiCuối
Kết quả 161 đến 170 của 357
  1. #161
    Trích dẫn Gửi bởi skyshort
    không sao đâu bạn.bạn cứ nhấn igore là được,nếu save lại được thì đã patch thành công
    Thanks bạn, mình đã làm thử như bạn nói rồi nhưng patch vẫn không thành công. Đây là mấy cái patch mình xài:
    ;W760 R3EK002
    ;Advanced range of brightness adjustment
    ;Allows you to adjust brightness from 10 to 100%
    ;© IronMaster
    ;(p) santae3
    ;pAtChFiLe=/boot/phone_app.cxc
    10E5EFF8: 401D 401C
    10E5F2F0: 262801D200207047312801D2 00B50149884700BD6B776812
    10E5F31C: 042810D801A1095C8F44C046 00B50149884700BDB9776812
    10E5F486: 0522 0922
    10F04A52: 242A01D22422 0A2A01D20A22
    1268776A: 00000000000000000000000000000000 142801D2002070471E2801D201207047
    1268777A: 00000000000000000000000000000000 282801D202207047322801D203207047
    1268778A: 00000000000000000000000000000000 3C2801D204207047462801D205207047
    1268779A: 00000000000000000000000000000000 502801D2062070475A2801D207207047
    126877AA: 00000000000000000000000000000000 642801D20820704709207047FFFF0828
    126877BA: 00000000000000000000000000000000 1AD801A1095C8F44C0460A0E12161A1E
    126877CA: 00000000000000000000000000000000 22262A000A207047142070471E207047
    126877DA: 00000000000000000000000000000000 28207047322070473C20704746207047
    126877EA: 000000000000000000000000 502070475A20704764207047
    ;W760 R3EK002
    ;megabass HZ(63.250.1000.4000.16000) to clearbass HZ(clearbass2.400.2500.6300.16000)
    ;Original idea by machao44
    ;© blacklizard
    ;(p) santae3
    1205CA7A: 65712D62 67CA0512
    1205CA85: 65712D62 91CA0512
    1205CA9D: 65712D62 A9CA0512
    1205CAB7: 65712D62 C3CA0512
    ;W760 SW-R3EK002
    ;Enable equalizer without headsets connected
    ;(C) 2007KrasH
    ;(P) DaNiElCoRe
    10D2624C: 11D0 C046
    ;W760 R3EK002
    ;Heap shift! more stability for patches!
    ;(c) den_po
    ;(p) santae3
    ;v.64k
    ;info 4 patchmakers: 4BBF32B8--4BC032B7
    ;this info is firmware version dependent
    1273291E: C8204003686080200001 0149884701E05101BC11
    11BC0150: 00000000000000000000000000000000 0CB51921090400230122920303600430
    11BC0160: 00000000000000000000000000000000 0439013AFAD1286069600CBC0120C002
    11BC0170: 0000 00BD
    Liệu có lỗi nào trong các patch không bạn :-S
  2. #162
    e ko đăng ký đc trên Aerix các bác ạ,nó cứ báo invalid email address :-(
  3. #163
    Trích dẫn Gửi bởi newplayer26
    bác save lại từng patch từng file 1, bác check xem patch có đúng với FW đang dùng ko
    mà sử dụng cách 1 ý, có nhiều patch ko sài đc bằng Far :|
    ---------- Post added at 18:53 ---------- Previous post was at 18:52 ----------
    Trích dẫn Gửi bởi phuctm82
    pm em nha bác .........................
  4. #164
    Mình đã thử cả 3 cách rồi, thì kết quả như thế này:
    Cách 1: làm tuần tự y hệt như bài hướng dẫn, nhưng đến khi reboot lại thì ko thấy có tác dụng j cả.
    Cách 2: mình đang làm giữa chừng thì chương trình down nên cũng nghỉ lun.
    Cách 3: như lỗi lúc trước mình có đề cập đó bạn, cho patch vào thì nó toàn kêu mismatch (cái thì 2/2, cái thì 72/74....), mình thử ignore rồi save lại nhưng khi khởi động lại máy thì vẫn ko có j thay đổi cả.
    :77::77::77:
  5. #165
    :| chắc cái patch có vấn đề :76:
  6. #166
    có khi mình đợi về sau A2 được patch phổ biến thì mới tiếp tục, còn bây h xài vậy cũng là quá đủ rồi (vì hồi trước mình định mua nokia X3 chứ hok phải em w760 này )
    BIết thế hồi trước mua nokia X3 cho rồi, mua sony về rồi không ngày nào được yên cả =)) =)) =))
  7. #167
    Bác post thử đoạn patch mà bác muốn patch lên đây xem nào? có khi patch đó bị lỗi cũng nên. Vs lại máy dùng được hay không là do người sử dụng, bác nói thế này thì oan cho SE và anh em trên này quá )
  8. #168
    Trích dẫn Gửi bởi Mr.Green
    Mình ko có ý trách móc j đâu, bác cứ nhìn cả đoạn sẽ hiểu ý mình mà =)):113:
    Còn đoạn patch thì mình có post ở trước rồi, h mình post lại, đây là mình gộp từ 4 patch đó:
    ;W760 R3EK002
    ;© IronMaster
    ;(p) santae3
    10E5EFF8: 401D 401C
    10E5F486: 0522 0922
    ;W760 R3EK002
    ;© blacklizard
    ;(p) santae3
    ;W760 SW-R3EK002
    ;(C) 2007KrasH
    ;(P) DaNiElCoRe
    10D2624C: 11D0 C046
    ;W760 R3EK002
    ;(c) den_po
    ;(p) santae3
    ;v.64k
    11BC0170: 0000 00BD
    Hồi trước hok dám mua Sony vì sợ giá mắc nên hok biết j, nhưng biết xài rồi thì chỉ có Sony :X:X:X
  9. #169
    có thể do patch của bạn không hợp với Main FW, hoặc khi bạn copy thừa ra những khoảng trắng8->8->:114::114::114:
  10. #170
    em cũng bị y chang như vậy, bro giúp e với, thanks mọi người:63:
